I am new to the VCD community, but I am hoping someone can help. I have been recording television show on the computer and tring to make aVCD out of them. When I play them on my DVD player they look very grainy. I have another video that I have downloaded from the net and I burned a VCD from it and it looked great. My question is how can I find out the bitrate and frames settings from the downloaded file so that I can reset my tv show to look as good?
When you record off the TV, try capturing it with the best quality setting your capture card can do, then convert it to Mpeg. It is most ideal to capture in AVI format. Try using HUFFY lossless codec which you can download for free, but it uses a lot of HD Space. The better the quality of capture, the better to convert. The files you downloaded from the internet are probably ripped from DVD's, which is quite difficult to match with the capture equipments you have, unless you have real expensive professional capturing equipments.
Help Reducing Bit Rate on video
By Aleahsmom in forum Video ConversionReplies: 2Last Post: 28th Apr 2011, 13:47 -
Video 'jumps' steadily at the rate of about twice per second.
By clausont in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2009, 20:25 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 17:07 -
Data rate for HD video
By spandau in forum EditingReplies: 3Last Post: 21st Nov 2007, 13:23 -
Video rendering rate?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th May 2007, 22:57
