  1. HI, I just bought the philips 642 dvix certified player recently and I have some videos that are 640*480 res. The players resizing cuts off the top and bottom. Thus, I have problems reading subtitles.
    Does any one know how to fix the problem?
    I have been playing with the 4:3 and 16:9 resolution on the player and tv and it doesn't fix the problem cuz it still automatically adjust the avi file. What res i can put my files at so it can correctly size them. And is there any fast way to change the res without reencoding them? Probably by changing the options on the tv or the player.
    Thanks much!
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Are you sure it's the player that cuts the edges off? I'd say it's the TV - it's called overscan. If improperly positioned, this causes subtitles to be cut off. Solution? Place your subs higher up when encoding.
    If the subs are a separate file (I don't think so in this case?) the player is responsible for positionin them correctly...
    /Mats
  3. reccamaster :
    im experiencing the same thing as you are having as problems...... i updated the firmware it didn't help one bit.....
    if i can't figure a way to enjoy anything on this player during this week or so....i will return it for sure ,.... it has been a pain in the *** & it played half of the divx xvid correctly ..... (problems that occurs often... skipping,sub cuts....file just wont play....& sound prob, & pixeleration (that is kinda normal depending)
    i am in the same position as you & calling for help
    each file i try is a new problem for me hehe (in the last 7 days i must of posted 10 or more topics about problems)
  4. Sigh,
    I just bought this player from amazon.com
    man....I have the same problems with subs etc and also most anime films sub were cut.
    But it's still a good dvd at a good price....you can't really get avi player for this cheap and I believe the more expensive ones might have the same problem.
    I am just going to keep it cuz I don't have a dvd player at all.....
