When I export a movie from Premiere in DV I can watch it but if I try to load it up in TMPG to Convert it to MPEG, TMPG says it is unsupported. Can someone give me some info on what to do because exporting to non DV seems to take forever.
Results 1 to 14 of 14
it's pretty much all default premiere settings
Compressor: Mircosoft DV (NTSC)
Frame Size: 352 by 240
Pixel Aspect Ratio: D1/DV NTSC (.9)
Frame Rate: 29.97
Depth: Millions, Quality 100% -
Remember, if Direct Show is already set as the highest priority, move the video to higher root directory. Like C:, rather that C:\blah\blah\blah...
Hello. -
Of course it does. Some of us were still getting "unsupported" monster even with Direct Show set properly. Someone posted this solution to the joy and wonderment of all.Originally Posted by bugster
Hello. -
I had the same problem. Install the Panasonic DV Codec and that should resolve it for you....
The distance between genius and insanity is measured only by success... -
Nope. Actualy it hannging on the audo of all thing.
Click the TMPGE menu Options.
Select Enviromential Settings.
Select tab Vfap Plugin .
Write down your current arangement before doing the next steps.
Make sure Direct Show is first. And or Priority set to same or one more than what ever the highest is. If no. Make it so.
Should have no problems.
We covered that, Night Wing. Having a file too deeply nested causes the same problem.
Hello. -
Actualy I typed it fully out to help any other reading this post in the future.
i ususally put the exported files on my desktop meaning yes they do have the long directory but the non dv still fire up fine
Try frameserving. I use the Debugmode frameserver with Premiere 6.0 to TMPGEnc and it works a treat.
Export as RGB...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I used that canopus dv converter and it did the trick even with the long drawn out filename
VRO conversion problems
By stellabelch in forum Video ConversionReplies: 3Last Post: 14th Oct 2009, 07:22 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 03:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 01:40 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 11:08 -
film conversion problems
By hobo20212 in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2007, 08:52
