Hey,
Got a neat set of Ultraman DVDs (8 discs, 39 episodes) and I'd like to make a backup set in case these get scratched.
I have a G4/1 GHz running 10.2.8, with a Pioneer DVR-106 inside.
The DVD won't mount on my desktop. Toast 6.0.7 does see it, however, and here's what it shows:
Shouldn't the format be UDF, not ISO9660?
DVD Media Inspector tells me it's a Taiyo Yuden DVD+R, and it appears as though the session hasn't been closed by whomever burned it.
Any ideas how to mount or copy this disk? I've got a slow Win98 PC with a DVD-R only drive, so that probably won't be any help.
Handbrake sees it, but I don't want to compress it, I just want to COPY it.
Suggestion?
dk
if toast can see it, can you make a disc image (file > save as > disc image) from toast to your harddrive, then burn that?
pants on, pants off, pants the floor. -
MacOS 10.3 and above is required to mount DVD+R discs.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
i would suggest pants idea, because then you can burn it to -r and make sure its UDF
i have a 2nd partition w/10.3.7 on it, i'll try a reboot & see what happens.
will also try to do that w/Tozt.
dk -
well, didn't reboot into 10.3 yet, but was able to just use the Copy feature of Toast. even though the disk wasn't mounted, it copied to a DVD-R just fine!
dk
Buying a monitor mount
By A Traveller in forum ComputerReplies: 6Last Post: 22nd Dec 2016, 23:26 -
Mount a game disc or file
By slayer_of_all in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2010, 14:18 -
lcd wall mount help.
By nick101181 in forum Off topicReplies: 2Last Post: 13th Dec 2009, 08:20 -
pioneer dvr106d burns but won't mount dvds on my mac g5
By muscmp in forum MacReplies: 6Last Post: 27th Jun 2008, 22:15 -
Camera Mount Instructions for a Bicycle
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jun 2007, 15:42
