Hi,
My limited understaind of deallilng with 16:9 video, is that it had to be shot in that manner in order to produce a 16:9 DVD.
But, i was thinking, is there anyway to convert a 4:3 video to a 16:9 format? Let me explain what i was wondering if i could do. I have some old video's that i wanted to convert to a 16:9 format, for my own personal use.
I want to take them to DSP and then burn it as a 16:9 dvd.
Is there any software that would take a 720 X 480 video and convert it to the 854 X 480 (i think) resolution needed for a 16:9 resolution?
Russ
Why would you want to do that?
In order to change the aspect ratio to 16:9 you would have to either:
1. Stretch the video horizontally, distorting the picture.
2. Crop the video, chopping off part of the top and bottom of the picture.
When a Hollywood film gets reformatted to 4:3, part of the picture gets chopped off. Hollywood 16:9 films are good because they maintain the original formatting and aspect ratio of the film.
My advice, keep the original formatting and aspect ratio of the video, unless your trying to do an artistic reinterpretation. -
The best way would be to produce a letterbox effect, such as in FCP. It'll mask out 4:3 video to 16:9
converting movie to HD but low space format
By shahzadashraf30 in forum Video ConversionReplies: 7Last Post: 23rd Aug 2011, 06:32 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Converting a Shockwave file (non-movie) to FLV movie
By beyondthegrave in forum Video ConversionReplies: 3Last Post: 22nd Nov 2007, 01:18
