Hi, this is my first post.
I am having a problem finding a program that I can use that will enable me to shrink vr files. I would also like to shrink, trim and title programs recorded on DVD-RAM and then burn to DVD-R.
Is there a single program that will do this ?
As I am a newbie, I would like a simple piece of software to use.
I've tried DVD-Shrink, but it will not accept vr files.
Thanks in advance !
TMPGEnc DVD Author will accept DVDRAM VR files -- you can trim them, etc, and author and burn to DVD-r ,all with that program, although I believe it's only the latest versions that will allow you to burn the final DVD.
If you do need to shrink the final authored DVD before burning, then you can do that using DVD Shrink -- the TMPGEnc output is a standard DVD format, unlike the original DVD RAM VR files. -
A couple of different ways to do this. Personally, use TMPGENC DVD Author. You can however, change the .vro file to a .mpg and then edit it with any editor.
DVD-RAM 10x, 12x discs - who sells them?
By rjamesd05 in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Sep 2009, 22:56 -
DVD-ram 2.8GB discs rip trouble
By wodfer in forum DVD RippingReplies: 1Last Post: 27th Jun 2008, 13:49 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32 -
DVD-RAM discs causing Panasonic DMR-ES10 recorder to 'fall-over'.
By dreamcloud9 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 7th Mar 2008, 00:24 -
Extracting .VRO file from DVD-RAM to pc for editing
By mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 14:25
