hi, friends,
recently i bought a brand new dvd writer and i have burned so many videos from my v8 and hi 8 tapes. now here comes my problem,i have also so many vcds and i want to transfer them into a dvd quality.
could anyone share to me what kind of softwares that will encode vcd format into at least a nice dvd format.
thank you in advance!!!
Hello,
https://www.videohelp.com/convert
Look up vcd to dvd.
You won't magically make it look like a pro dvd because you convert it. It won't look any better than the source. And you can get a loss in conversion simply because of the process.
Kevin
(If you still have the original tapes recapturing in dvd mpeg2 mode will yield better results then reencoding the vcd's. Though it will take time since it will be a realtime capture again - but it will be all set for dvd authoring
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
the original tapes were lost already.that's why i'm inquiring if there's such a softwares that will solve my problem! thank you anyway for helping me!
No don't re-encode!
Do this instead:
Extract the MPEG file from your existing VCD's using ISOBuster.
Demultiplex the MPEG's using TMPGEnc's MPEG Tools.
Use those files to create a DVD using DVDAuthorGUI.
This won't give you better quality but it will be faster and preserve the existing quality.
None of this is worthwhile however except if you really hate swapping the CD's.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
