I'm using svcd2dvd v2. I have a large mpeg2 file (almost 3gig), which already has nav packs added by svcd2dvd (I don't have a non-nav packed version). It is a music recording I took from a vhs tape. I can put this mpeg onto dvd using svcd2dvd without a problem, but i wanted to enhance the audio...
I demultiplexed, enhanced the audio then used tmpgenc plus to multiplex the new audio with the original video. The nav-packs vanish in the process (according to svcd2dvd or mpegdetails).
Once I rebuild the dvd with svcd2dvd with this new mpeg, everything appears fine (and it'll play in WinDVD), but when I try the DVD in a standalone player (i've tried 2 and an xbox), the video shows lots of pixellating and the sound isn't present.
Any ideas?
here's the details (from mpegdetails) of the working original file:
2.98 GB
mpeg2video
PAL
352x576
4013Kbps
Yes
mp2
48000
224Kbps
and here for the non-working file after multiplexing with new audio:
2.94 GB
mpeg2video
PAL
352x576
3963Kbps
No
mp2
48000
224Kbps
(The Yes/No corrspond to nav packs, the rest is pretty obvious i think) -
/me slaps himself with stinky trout...
Solved the issue myself... Although SVCD2DVD reported the mpg contained mp2 audio, I had actually multiplexed the video with mp3 audio. I converted the mp3 to mp2, re-multiplexed, and now everything works absolutely great
I think i'll put this one down to my own stupidity
Hey bubbz,
You obvioulsy like to tinker with stuff. Hats off to you for that. Also you know what you expect and so can solve you own issue!
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Problem trying to play DTS audio
By seven_deuce offsuit in forum AudioReplies: 14Last Post: 5th May 2008, 00:49 -
What software can segment multiplexed video?
By forensic in forum EditingReplies: 4Last Post: 13th Mar 2008, 10:08 -
Sound stream stopped working after being multiplexed
By moviebuff2 in forum Newbie / General discussionsReplies: 7Last Post: 29th Oct 2007, 21:21 -
Change Aspect Ratio from 4:3 to 16:9 on Multiplexed MPEG2
By VVid in forum MacReplies: 11Last Post: 14th Oct 2007, 09:39 -
Play back problem with audio pitch
By Silverknight in forum AudioReplies: 3Last Post: 7th Aug 2007, 00:03
