hello all..
i was wondering how do i make a dvd movie with a menu that loads up and a menu screen comes up with 2 options one of the options is to watch a video and the other option is to watch a picture slideshow
anyone help me with this?
could i do it with nero?
also i dont know if im posting in the right section so sorry moderators if im not and could u please move this to its appropriate area.
thanks
I just created a slideshow in Nero, and then let it save to the HD. Extracted the single VOB (it was a short slideshow), and combined it with my movie in TDA as separate tracks. Then on the menu, one track is for the movie, one for the slideshow.
I'm not as familiar with all the guides here as many others, but I can start you off by saying if you want to use Nero for your slideshow, follow the wizard all the way through to the menu option. Let it use the default menu since you'll strip it out anyway. Continue to the burning step, then select "Write to directory".
At this point, you can select the VOB(s) as input to TDA (authoring program). Once you're at this stage, there are tons of guides on this site to help you continue. I'll see if I can find a link to one for you unless someone else posts one first. -
You could use Slide Show Movie Maker to make the slideshow and then create the menu with GUI for DVD Author.
ok so i kinda see how to make the dvd picture slideshow but how do i make a menu and add on a video?
Hi AeR0,
It seems you can get to the point where you've got your 2 DVD compliant MPEG2 files / VOBs - one for the video, one for the slideshow.
In a DVD authoring program (the one suggested was TDA = TMPGEnc DVD Author), load up each file into it's own track (use "Add DVD video" for the VOBs).
From here, you can create chapters in each track. See here for an explanation to tracks and chapters...
When you put the finished disc in, you'll get the menu you made showing the two tracks - one for the video, and one for the slideshow.
Hope that helps... Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
DVD to a single MKV with menu navigation screen
By rexdude in forum Video ConversionReplies: 3Last Post: 7th May 2011, 12:24 -
Pinnacle DVD menu green screen SOLVED!
By Surg1951 in forum Authoring (DVD)Replies: 2Last Post: 27th Feb 2011, 16:12 -
video menu on screen is wonky
By NDirect06 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Jan 2011, 11:31 -
Subtitles appear in the menu but no on the screen
By dexter30 in forum SubtitleReplies: 4Last Post: 25th Feb 2010, 22:35 -
Philips DVDR3475/37 Menu Scene screen
By dblan9 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Mar 2008, 15:53
