    Jul 2001
    Maryland
    It seems that something has altered my file assisiations.
    In My Pictures, files with the ending ".JPEG" display properly but files with the name "JPG" don't display.
    What should i do?
    I want my JPG's to be normal.
    Feb 2001
    Berlin, Germany
    Start from the windows explorer, >extras> directory options> filetypes (or similar). Watch out for JPG. If it isn't there, create a new filetype JPG. If you find it, but no command which tool should open the .jpg file, select your favorite software, that should do it, for example Photoshop.
