  1. Hi
    I have a big problem with my NEC 3500AG rev. 2.7 (lacie shipping) and toast 6.0.7, the dual layer recording don't work, BTW I use traxdata DVD+R DL.
    Toast report a misterious "Interface error: -50 The connection is not stable." but all work fine with DVD+-R & RW, only DL have this error.
    Searcing on google I have found this discussion forum (PC users) and seems that the problem is the software...
    http://www.cdrinfo.com/forum/printable.asp?m=92378
    Any hint or suggestion?
    Do you have some experience with DL burning?
    Nerone
  2. I would try Verbatim media since it is the only one really supported by most DL drives.
