I'm using Ulead Video Studio to edit and render, my source files are from a DV camcorder in AVI format. My question is this: Under Project Options I can set the compression for MPEG2 or NTSC/DVD which do I choose and why. The only difference I see when selecting them is in the audio section, MPEG2 uses AudioType->Stereo 4800hz at 224kbps and NTSC/DVD uses AudioType->LCPM. Video rate for both is 6000VBR. I understand that it is best to match the project properties with the content being used but I'm not sure which is best. I get prompted for the same thing when I go to render, is one better then the other?
Hello,
The audio would be ac3/mp2 or LCPM.
LCPM takes up the most space as its uncompressed. To increase video space use ac3/mp2.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 28th Sep 2009, 00:05 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 16:07 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 19:26 -
NTSC mpeg2 to pal needed
By Caned_and_Able in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 22:13
