Anyone with this card want to comment on the video quality on the Winfast PVR program?
When I use that program to watch TV, I get a lot of lines across the screen. I do not think it is the aftereffects of deinterlacing because it always appears across the screen, not on a specific portion of the picture.
I might have to send the card back if you guys have a clear picture.
Thanks!
I had the card and using the tv tuner i got lines but not with vhs capture.
Really? What program did you use for VHS capture? PVR?
Are these the lines you are referring to:
http://ucsu.colorado.edu/~auyeung/a.jpg
http://ucsu.colorado.edu/~auyeung/b.jpg
I still get them when I record. Perhaps I need to change some settings? -
I used virtualvcr and still use it.The lines i had were more herringbone,what you have is macroblocking which is low bitrate for a capture file.
TV2000 XP Expert No Sound
By cbr549 in forum Capturing and VCRReplies: 5Last Post: 5th Dec 2010, 13:29 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
