Pioneer web site has nothing on the 220S.
It looks the same, anyone know for sure????
The Pioneer DVR-220/225 doesn't have a DV input, otherwise it's almost the same as the 320. Also see the following:
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=487289 -
I have the 220 and the manual that came with it is for both the 220 and the 320. The only difference between the two is the 320 has the DV port(firewire) and it is a two way port according to the manual i.e. video from or to your DV camera or computer.
Now if i can just figure out how to setup the DVD menu to show pictures, manual only has about 10 lines telling how to get to the menu screen. -
Originally Posted by MikeV
Thanks for the info. I'll try it tonight when I get home from work.
Originally Posted by nickyboy4
https://www.videohelp.com/forum/viewtopic.php?t=220022
I have scan the output from 320S and I am sure the recording is in VBR.
Is the scan of the 220S incorrect or 220S is really using CBR?
Can anyone do a scan for the recording on 220S again?
Replacement for dead Panasonic / Matshita UJ-220S with ATA interface
By Persistence in forum DVD & Blu-ray WritersReplies: 1Last Post: 21st Feb 2010, 09:53 -
Need help with Pioneer DVR 220S Intermittent recording problems
By horhota in forum DVD & Blu-ray RecordersReplies: 6Last Post: 3rd Nov 2009, 06:27 -
Need to replace burner in Pioneer 220s
By Brent G. in forum MacReplies: 6Last Post: 12th Nov 2008, 16:33 -
Pioneer DVR-220S and TDK (CMC MAG, AM3) discs incompatible?
By cwerdna in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Nov 2008, 15:25 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 12:59
