ok i will try to go into as much detail as possible about my issue
1. I got a Pacific Digital U30183 External Dvd Burner (shows in device manager as *Nec Nd-1300A* for christmas and it woudnt burn dvd-r discs so i downloaded a NEC ND-1300A driver and now i can burn -r discs but im burning at like .07 i mean not even burning at 1x on a 8x dvd-r but thats not my only problem..
I am using CloneDVD2 to backup my dvd's and it does the whole process for me after i choose what i want to keep as in *MENUS,EXTRAS,AUDIO TRACKS,* and i backed up E.T 20th ann edition the other night wich is 2 hours plus about 20 mins of extras and the whole process took *4Hrs 23Mins* that just seems WAY to long doesnt it?
Here is what im running it on
Hp Pavilion
800mhz
256Mb ram
I know its not fast pc but im sure it shoudnt take 4hrs 23mins to make a backup
Here is the exact process i use
1. Put dvd in dvd rom drive (not dvd burner drive)
2. Put Blank DVD-R in dvd burner drive
3. Start AnyDVD
4. Start CloneDVD2
5. In CloneDVD2 i click the middle option wich is Clone a DVD including all titles and menus
6.Then I choose the Video_TS file of the dvd in my dvd rom drive
7.Then I Click Next
8.Then I Choose what audio tracks i wanna keep (single Audio Track Usually(
9.Then i click next and choose my dvd write and speed *i choose 4x*
10.Then I Click GO and let it do its thing wich took 4Hrs 23Mins for the last one i did (wich was the only one i have done so far)
So i need some help please
Results 1 to 10 of 10
How is the external drive connected. With a PC that old, it is either parallel (using a mock scsi driver) or USB 1. Both of these are very slow, and I can image would limit your data throughput to the burner enough to cause this.
If the burner is an internal burner in an external case, try swapping the DVD-Rom and burner around. You will get slow rips from the rom (or rip from the burner for better speed), but full speed burns from the burner.Read my blog here.
The DVD burner is external connected through usb 1.1 and the dvd rom drive is internal
but why should it be so slow since im using the dvd rom to do everything except the actual burning itself?
do you think buying a usb 2.0 slot for my pc would speed things up?
even though its connected through usb1.1 shouldnt i still be able to burn at full speed?
also shouldnt my internal dvd rom be able to rip faster then it is ?
Any more help would be appreciated -
First things first
On the fly copying is not encouraged. It is wayyyy to easy to have errors and mess up what you are trying to do.
Buy a usb2 card
That might help. -
By the way here are the specs for my dvd-rom and dvd burner just so you all know incase this will help someone help me
DVD ROM Toshiba SD-R1312
Read Speed 40x (CD), 12x (DVD)
Write Speed 32x (CD)
ReWrite Speed 10x (CD-RW)
Nec ND-1300A DVD BURNER
Read Speed 40X (CD) 12X (DVD)
Write Speed 16X (CD) 4X (DVD)
ReWrite Speed 10X (CD-RW) 2.4X (DVD-RW +RW)
Hope this is some help to the people willing to try to help me -
A USB 2 card, assuming the burner supports USB2, should bring your burn down to about 13 minutes (true x4), as opposed to the hour or more it is currently taking.
Use DVD Decryptor to rip to the HDD (if you have a spare 8GB), then process and burn.Read my blog here.
Check Newegg.com for PCI USB 2.0 Cards. And get yourself another stick of RAM. You deserve it.
Just a couple questions real fastOriginally Posted by guns1inger
1.Can you point me to a guide for the best way to RIP to hdd using dvd Decryptor and will it make a ISO image?
2.Will it just rip all the vob files then i have to make a ISO image?
3.Will it just rip the vob files and i burn them as data?
sorry but im new to dvd burners -
If you read the box it cam in it should say USB2.0 as a part of the requirements.
I didn't find your exact model but a similar $X external shows as follows:
The U-30194 is the most universal portable DVD recording solution available today.
Pacific Digital's 4x ‘Dual' Format DVD writer connects to either a USB 2.0 port OR a Firewire (1394) port and supporting both DVD+RW and DVD-RW media.
I suspect that yours is more or less the same model minus the firewrae option. You will notice that it shows USB 2.0, A HP 800 Mhz has USB 1.1 much, much slower throughput to the drive. Be glad it even works with 1.1
Cheers -
get a firewire card....usb has compatiblity issues when using a dvd burner.....
Speed Edit 2.0 issues with Alpha Channel with .avi file
By Ubercoyote in forum EditingReplies: 3Last Post: 22nd Nov 2011, 18:47 -
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 10:49 -
VHS tape speed issues
By mjjohnston in forum MediaReplies: 11Last Post: 10th Feb 2010, 09:14 -
multi LG Gh22np20 write speed issues
By mistermofo in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th Jan 2010, 19:37 -
Interalce and speed issues using VirtualDubMod
By tgolsby in forum DVD RippingReplies: 5Last Post: 10th Feb 2009, 22:10
