Hey guys, my first post. First let me say how much of a help these forums have been since I got my dvd burner, took me about 3 days of constant reading here to actually learn every aspect of burning a dvd correctly, had no idea it was so involed. But I got it down now... Anyways I have a disc image of Star Wars Ep. II (dual layer) and I have a single layer only burner. Is there any way to cut it down (remove all the extras is ok, just want the movie) so it will fit on a 4.7 GB disc? The movie itself is only like 2 hours so I'm hoping there's some way I can. I searched and haven't found this question but flame away if I missed something. Thanks in advance.
Originally Posted by jagojon3
It takes a long time to grasp every concept.
Good luck.
DVDSHRINK in reauthor mode, I second the suggestion.Want my help? Ask here! (not via PM!)
lol ok maybe not "every aspect" but I know a billion times more than I did before. Thanks I'll give dvd shrink a try.
go to www.dvdshrink.org and look in the guides section.
There are a number of "shrinkin' " programs out there, but a good freeware tool is dvdshrink. -
Lots of guides, you just need to know how to do a search, click here.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
