I have an image file of a linux install I did that I want to backup. The image file is 15 GB, but 7GB (maybe more if I can delete some more stuff) is freespace. Is there a really high compression format that would let me shrink that down to 4 GB so I can burn it on a dvd for a backup copy? Do you have any links to this piece of software?
Results 1 to 17 of 17
You can use Winrar to split it into 4 pieces for burning to DVD.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Thanks I tried that, but Uharc only supports files 2 GB and under. Any other ideas?Uharc might squeeze it...Google it.
Is the image already compressed?
Nothing can stop me now, 'cause I don't care anymore. -
No, its just a regular .img file. I have around 8 GB of the 15 free now, I could delete more (wine is taking up alot of space) but I'm not sure if they are wine temp files or not. Any ideas on how to compress (basically 7 GB now) down to 4 GB would be great!Is the image already compressed?
Try Stuffit.
http://www.stuffit.com/win/index.html
They give you a 15 day trial on the standard version. -
I thought Stuffit was only for Mac OS X- you learn something new each day. Back when I had a Mac I was able to dl Stuffit and keep using it forever (free), I wonder why they don't do that with the windows version?Try Stuffit.
its not free for mac either (now) ..
WinRK 2.0 has the BEST compression of any program ..
just so you didnt think i made this up ..
first 20 best compression
1 WinRK 2.0 9412939 100.0
2 PAQAR 4.0 9675449 102.8
3 DURILCA 0.4b 9891049 105.1
4 SLIM 0.23d 9905919 105.2
5 EPM r9 10179845 108.1
6 RKC 1.02 10411833 110.6
7 COMPRESSIA 1.0b 10664630 113.3
8 PPMonstr Ir1 10799660 114.7
9 ENC 0.15 10939309 116.2
10 ASH 04a 10966623 116.5
11 Ocamyd 1.64 11122410 118.2
12 UHARC 0.6 11151014 118.5
13 7-ZIP 4.13b 11300395 120.1
14 RK 1.04.1 11454328 121.7
15 CTXf 0.75 b1 11587323 123.1
16 WINRAR 3.42 11601931 123.3
17 STUFFIT 8.5 11702399 124.3
18 PPMN 1.00b1 km 11733001 124.6
19 GRZipII 0.2.4 11805752 125.4
20 RKUC 1.04 11825088 125.6
http://www.maximumcompression.com/
http://www.maximumcompression.com/data/summary_sf.php"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
PAQAR is also very good btw -- but a little slow ..
as are all the max compress methods -- they are doing a huge amount of number crunching ....
splitting it seems like a better solution"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks alot for your detailed response, that was exactly what I was looking for- figures of each compression type compared to each other.PAQAR is also very good btw -- but a little slow ..
Why do you think splitting the file would be better? Because compressing would take a long time? -
I found a GUI for PAQAR:
http://guiguy.wminds.com/forums/viewtopic.php?topic=495&forum=3&5 -
compressing 15 gig block will take a long time -- AND it might not compress enough even then ....
the top 2 are 20% better compression than winrar (using max settings)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Like I said though I have 8 GB free on the image file, wouldn't that 8 GB just compress to almost nothing, leaving only the other 7 GB to actually be compressed?compressing 15 gig block will take a long time -- AND it might not compress enough even then ....
the top 2 are 20% better compression than winrar (using max settings) -
yez - true .... ( i missed that part)
What about Norton Ghost? You don't even need Windows installed on your PC as it will run from a Win98 Start-up disc DOS prompt.
This isn't for windows, its for a linux image file.What about Norton Ghost? You don't even need Windows installed on your PC as it will run from a Win98 Start-up disc DOS prompt.
Cannot append, files use different compression
By PirateBill in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2009, 21:04 -
Help with choosing compression for DVD files
By BooBerry in forum DVD RippingReplies: 1Last Post: 16th Apr 2009, 10:47 -
optimal compression of those raw files?
By Fking in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2008, 13:33 -
[NSFW] what compression was used in this high quality video?
By nargisform in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2008, 10:16 -
Compression, conversion, and splitting of MOV files
By weareone in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 12:07
