Results 1 to 18 of 18
  1. Hello.
    There is someone who know how to decrease the DVD convert option in mainconcept tool (make a lower quality or something else...) that the MPG file Target will not be large by 10 proper than the Source file ?
    Thanx.
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    From what you have written I don't have enough info to know what you are trying to do.
    look here for a guide to encoding a file with main concept written by lord smurf.
    https://www.videohelp.com/forum/viewtopic.php?t=229193&highlight=mainconcept+guides
    Donadagohvi (Cherokee for "Until we meet again")
  3. I think you want to reduce the filesize in the finished dvd, not increase it's size by 10 times.
    If I'm right, just decrease the minimum, maximum, and average bitrate to what you want, or set it to CBR (instead of VBR), and reduce bitrate to any number you like.
    Beware the quality will suffer greatly if you reduce it to less than about 4000. 2500 is SVCD, 1150 is VCD, so you might want to consider encoding that way instead, then burning multiple (S)VCD to one dvdr.
    Cheers, Jim
    My DVDLab Guides
    Apr 2004
    Miskatonic U
    Let me guess - you have a movie you downloaded as xvid/divx at 700mb, and after encoding it is 6gb ? Welcome to the wonderful world of video compression.
    In Mainconcept, try using 2-Pass VBR, min 0, average 6000 max 8400. 90 minutes should fit on a single sided, single layer DVD.
    Read my blog here.
  5. I am having a similar problem with Mainconcept and Divx/Xvid files. When I try to convert them to mpeg2 ready for authoring the file size exceeds the size of my dvd-r's. I have tried the suggestions mentioned here and yet the file size remains unaltered.
    How do I resolve this please so as my files will fit on a single dvd-r ?
    Thanks.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    reduce the bitrate
    use https://www.videohelp.com/calc
  7. I tried that but it had no effect on the output file size.
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    then you didnt do it right - bitrate will change the file size
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    it is the avg one that is importaint in this case
  10. Ok, thanks for the tips. I think I have cracked it now. I changed the audio to level 2 from LPCM and that dropped it a hell of a lot. I then changed the average bitrate to the one that the bitrate calculator gave me (5931) but that didn't change the size by much.
    I then dropped it to just below the size that the calculator said (5900) and this dropped the file size to 4.3g.
  11. Conversion worked so thanks for the advice. Only thing is it looks squashed. It was a 2.35:1 source and I tried both the 4:3 and 16:9 settings but they just don't look right.
    What am I doing wrong ?
    Thanks again.
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Did the video have black bars top and bottom ? Even a 16:9 dvd will have the bars if the original AR is 2.35. If these have been removed then you will have to add them back first, then encode.
    Read my blog here.
  13. There were no bars at the top and bottom, it was like the image had been stretched vertically.
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It has been trimmed down to the image, which would be OK if it had been 16:9 to begin with. 2.35 is much narrower than 16:9 (which is approx. 1.778), so it will stretch, even on a widescreen TV. The only way around this is to add the balck bars to fill out the frame to legal resolution, then encode.
    We would have to know the resolution of your avi, and the resolution you want to encode at (e.g. D1, Half-D1 etc) to tell you more.
    Read my blog here.
  15. Член BJ_M's Avatar
    Jul 2002
    Canada
    MC has this feature built in -- btw
  16. resolution of the avi is 6058x256 according to Gspot. I am pretty new to this and just wanted it to keep as close to the original widescreen ratio as possible.
    Thanks.
  17. Член BJ_M's Avatar
    Jul 2002
    Canada
    i think those numbers may be a tad off
  18. Sorry for the typo, should have read 608x256.
