What is the best and fastest s/w for cutting mpeg-1 files ? I have a couple of files that I would like to cut into 2 different vcd's. Seems like everything I have tried so far takes forever or is difficult to use.
Please point me in the correct direction, since I am VERY NEW to this.
Thanks...
Research-aholic
It never ends !!
PC -
You have most likely tried the most common ones, and some are a bit difficult to use, and most are slow because you're dealing with huge files. So, unless you have a 2GHz CPU and a 40 gig hard drive, it's going to take some time to copy and process those mpeg files. The most common editors (cutters) for mpeg-1 is Tmpeg, MyFlix, Cineplayer Editor, M-1? editor, Womble and some others. See the Tools on the left side of this web page.
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 21:45
