I have a video clip in WMV, and the quality of resolution is good when I watch on my computer with Media Player in small mode. But when I watch in full wide screen mode, the quality is really bad.
I use Super DVD Creator to convert the WMV file to MPG for VCD format with ration 1:1 . The quality is still bad when I watch it on TV, I also convert with ration 4:1, still bad.
Is there a way that gives me a good quality as I watch on my computer?
The MPG is still good if I watch on my computer. Thanks
It sounds like the original resolution is too low. Any clip looks good on a tiny window, but full screen you can see the flaws.
It could be the original is some lower res that's unsuitable for DVD because of the amount of expansion it would need. Sounds like it might be 320x240 or worse
You need to get a higher-res version of it. There's no way to put quality back in it, or resolution, if it isn't there to begin with.
Quality problem editing DV
By ClaesPo in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 14:31 -
The Quality Problem
By alimustafakhan in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2010, 18:59 -
Problem with MKV to DV - Inconsistent Quality?
By aboutblue in forum MacReplies: 2Last Post: 19th Apr 2009, 14:54 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 18:14 -
quicktime movie quality problem
By photofun in forum MacReplies: 10Last Post: 17th Dec 2007, 04:14
