I authored a DVD with DVD-lab, with the option checked "force audio for all movies". The sound was a WAV file sampled at 48kHz. I then burned it with Nero.
It worked fine on my DVD player, but when I played it on a friend's dvd player the sound "skipped". Kind of like as if some little gremlin was turning the volume on and off and on and off. Really annoying. The picture was fine.
Is there anythging I can do about this?
Results 1 to 9 of 9
Was the audio file sampled at 16 bits or 8-bits? Have had exactly the same result with 8-bit audio files that I forgot to convert to 16bit before the encoding and authoring.
The more I learn, the more I come to realize how little it is I know. -
Good idea. But the WAV files I used were all 16 bit 48kHz.
any other's ?
Try reauthoring with another audio format like AC3 or MP2. WAV (LPCM) is uncompressed and a terrible waste of disc space. Use 48 KHz, 16-bit, 224 Kbps
I have plenty of space on the disc. I am only concerned with quality/performance right now. So would these formats give a better quality and solve the problem of the skipping? or would they simply result in smaller files that still had a skip error on the dvd?
i've had the same problem, it was caused by some dvd players having trouble with certain audio formats, i would use ac-3, it's universally compatible, and because space isn't a problem you can use a high bit rate. i use ffmpeggui, you can go as high as 448 on the bitrate, which is very good quality
member since 1843 -
Originally Posted by sharktacos
WAV (LPCM) is obsolete for audio. It was required in the early NTSC definition for DVD audio. Early players were required to support it to be fully compliant.
Nowadays compatibility is more an issue with LPCM than with the other two common formats, and some players could choke on it. Give AC3 a try -
ok, I'll try another format and see how that works.
Thanks for the help everyone
sound problems. GSpot 2,52
By camino camino in forum Video ConversionReplies: 0Last Post: 13th Jul 2010, 05:44 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36
