Hi,
I want to purchase a good capture card in the $100 range for converting VHS and CamCorder VH8? tapes to DVD. I have a computer that came with Roxio Easy CD and DVD Creator, but it has an S-video in only. I need the analog in.
Can you guys recommend the best card for the buck!
Thanks!
I have had great success with my ATI AIW 9200. It can be found for around $90.00.
http://www.tweaknews.net/reviews/aiw9200/ -
Hello,
The older ATI All-in-wonder cards should be in that range - the 8xxx series I believe.
The nice MPEG only Hauppauge cards are over $100 I believe (USD).
Try EBAY and/or the older 64mb ddr ATI cards still sold on some sites.
You can routinely buy ATI All In Wonder (AIW) cards 7000-8000-9000 series off of eBay for $50 or so. Be sure it comes with the PURPLE WIRES.
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 08:49 -
Who makes the best USB2 capture card for under $100?
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 7th May 2009, 16:52 -
In easy driving range of Staten Island, NY w/vid. capture experience? Read.
By fischkopf in forum Off topicReplies: 0Last Post: 2nd Jun 2008, 20:20 -
what's the best DVD player in the $100 range?
By j0e in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Sep 2007, 20:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
