got 2 parts on cd's & would like to convert to dvd. have copied to computer the avseq files but when i try to merge them together ready to encode tmpgenc says that they are not mpg files. I have downloaded all available codecs & changed enviromental sttings in tmpgenc but still no luck is it something simple do u think,
many thanx
yeah but it wouldn't recognise the files. Am using iso buster to open discs form rom to hard drive convert to user data maybe that will work. just copied the avseq over b4 by copy & paste
Hello,
You have to extract the mpeg2 data. That will get you the mpg file (even though its mpeg1 its still accesed by the "extract mpeg2" option).
Kevin
(and it has to be saved manually with the ".mpg" extension)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yes but you're re-encoding which should be avoided due to quality loss, it also takes longer. Baldrick's guide is best.Originally Posted by stillmars321
What's the easiest way to convert a PAL DVD to NTSC?
By snafubaby in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 21:21 -
The easiest way to convert dvd to mp4
By karib in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 17:01 -
Fastest & easiest way to convert files from dvd to upload to Youtube?
By scarypoultry in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jul 2010, 03:49 -
Easiest way to convert HD-DVD to Blu-ray?
By DGenerateKane in forum Blu-ray RippingReplies: 4Last Post: 27th Sep 2009, 18:04 -
Easiest way to convert episodes from a dvd to single episode files?
By Pj10 in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2007, 22:42
