I have the Epson R-200 printer. I would like to know if it is possible to re-ink the different cartridges. I have the Epson chip resetter, and it appears to reset the cartridges.
I tried to re-ink the black cartridge (I found 3 filler type holes on the bottom of the cartridge). I tried using one of the holes, but it seems to just bleed out the ink once I put it back inside the printer (original Epson cartridge).
I tried to re-ink the Megatoner cartridge (one filler hole on top). It also bleeds all the ink out.
Does anyone know how to properly, if possilbe, to re-ink the Epson R-200 cartirdges. Thanks........
Results 1 to 1 of 1
Best Media Player under $200
By 001dummy in forum Media Center PC / MediaCentersReplies: 9Last Post: 19th Aug 2010, 15:06 -
Best HDTV for 200 bucks??
By sandman423 in forum DVB / IPTVReplies: 19Last Post: 29th May 2009, 13:23 -
Looking For A Decent Camcorder Under 200$
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th May 2009, 11:13 -
BVP4 Plus for 200$ worth it?
By HOTPROPHET in forum RestorationReplies: 7Last Post: 22nd May 2008, 23:32 -
LG DAT-200
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th May 2007, 10:26
