I have a video file that keeps freezeing in the first few seconds except when played using VLC media player. I need to convert the file to vcd though, does anyone have an idea on what to do? According to AVIcodec the file is PAL divx5 and AC-3 sound
Results 1 to 10 of 10
Cut the first few seconds out with VirtualDub. Then follow one of these guides.
/Mats -
What mpeg encoder are you using?
Have you demuxed the audio AND video into seperate files with VirtualDubMod? -
Im trying to use tmpg, it encodes until the freeze spot and just holds the frozen frame throughout the video
Dump it. Get a better source. What's your hourly rate? How much time are you willing to invest in trying to fix what's maybe unfixable? Bad AVIs are rarely worth the trouble, IMO.
/Mats -
i think i may have found a solution, my other pc has a diff codec setup and it plays the video minus sound, so i think it may be possible to get the sound to avi then use the other pc and jam them together while converting to mpeg
Video Causing Computer to Freeze
By Ownaholic in forum Software PlayingReplies: 4Last Post: 26th Apr 2012, 13:10 -
.avi movies freeze when video is saturated
By HartsVideo in forum Software PlayingReplies: 21Last Post: 9th Dec 2010, 14:34 -
Video-TS files slow down and/or freeze
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 05:20 -
Video Freeze after Conversion to NTSC
By gcam in forum Newbie / General discussionsReplies: 6Last Post: 1st May 2008, 11:57 -
help: jerky/freeze video playback after using mencoder
By keratos in forum LinuxReplies: 22Last Post: 16th Mar 2008, 14:56
