  1. I have 3 of these player but i am having problem with 1. the problem is that it display in black and white for this 1 pal movie. i pop in that same movie on my other 2 player and it play just fine. the one that display in black in white is the first player that i bought. is there a crack for this to make it region-free?
    Computer Spec:
    winxp pro, 2.4ghz, 768mb ram, 100gb
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    The black and white issue is not region-free related. It is because it is pal.
    It either has no restriction or is already region 0 since you are able to play it all.
    You have to convert the pal to ntsc for it to play properly (assuming your in the ntsc zone which it seem slike you are ).
    Check the conversion guides under "HOW TO" on the left of the screen <---- Plenty of guides for PAL to NTSC. But it takes a lot of TIME and EFFORT to do it
    Kevin
