I converted a Divx file using WinAvi to DVD. It created a VIDEO_TS file and I was able to burn it without any problems.I was able to view the DVD without any problems until it reached chapter 8 on the DVD. Anyone know why this happen? Also is there a problem having a *.VOB file 4gigs on a DVD? I setup WinAvi to make a chapter every 600sec. Can that have been the problem?
Thank You in advance.
What happens after chapter 8? (That should be at 1.20, right?) What's the total running length? Bad media usually shows its ugly face at the end of the disc, so it could be a bad media issue. For dodgy media, keep the total size down at or below 4.2 GB to avoid the troublesome outer part of the disc.
/Mats -
My VOBs file was 4 gig's. That's what probably caused it. How should I use WinAVI? I've read the guide and I did it just like the guide explained. Anyone else is using WinAVI convert to DVD? What is your technique?
on output setting,constant video quality-select highest quality,winavi should make the vobs 1013mb in size,not really a big deal but you could change them to 1024 like jimm suggests.(definately NOT 4gig!)
if you want to do it by disc size,make sure that constant video is selected,and the disc size is 4300mb.as for chapters,try the standard 150 and see what happens.
and finally the preference should be set to "by quality".
these settings apply to version 6 and over,but dont hold out much hope on help from the team at winavi,i mailed them about an error on 6.2 and they sent me a mail saying to try the version they attached with the mail,it was version 5.8!. go figure. -
If I don't use there burning software should I need to author the DVD? Can someone post there exact settings using version 6.0 to be able to create a 4.3 gig DVD? I got a DVD file of 12 gig for a 1.2 gig DIVX file. How could that be??
Any considerations when burning WinAvi converted dvd to a DVD+RW?
By AshleyQuick in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:31 -
DVD Lab Pro - Play Chapter and return to menu
By SCDVD in forum Authoring (DVD)Replies: 4Last Post: 5th Dec 2007, 17:05 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 02:34 -
WinAVI Video Converter 8.1 (DVD gets stuck while playing on home DVD)
By Zuzuu in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2007, 13:37
