i've recently bought my first dvd burner for my computer. i'm trying to decide which dvd media to buy for it. what is the differnce between dvd-r and dvd+r and is either one preferable to the other?
whether you think you can, or think you can't, you are right.
-r is more compatible.
+r is technically superior.
If you want compatibility, go with -r. -
Or if you can change the book type with your burner
Use +R booked at DVD-ROM
Because from my understanding DVD-ROM is even more compatible. -
thanks bazooka, now its just a matter of deciding which brand to buy. i like taiyo yuden CD-r's so maybe their dvd's will be just as good.
whether you think you can, or think you can't, you are right. -
there were definitions about the 2 formats, but i didnt find anything about how the 2 formats differed. from what i read, the dvd-r's are more compatible with various players.
difference between burning DVD-4,7 GB and DVD-8GB
By michcio in forum DVD RippingReplies: 3Last Post: 2nd Jul 2009, 10:56 -
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 14:21 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
The difference between mpeg-2 and mpeg2-dvd in Premiere and the use in DVD
By umforrest in forum Video ConversionReplies: 5Last Post: 16th Jan 2008, 20:36 -
Can anyone actually TELL the difference between Blu-ray/HD-DVD over DVD?
By corvette77 in forum DVD & Blu-ray PlayersReplies: 62Last Post: 1st Dec 2007, 14:37
