Hi All
I have made a DVD with Toast 6.0.7 using two Mpeg files and letting Toast do the encoding etc....
I used two Mpegs part 1 & part 2
The two Mpegs when played in Quicktime are fine, but on Viewing the completed DVD the audio runs out of sync the further into a part it plays.
Any ideas?
Washac
yes , simple , though not very helpfull...
dont use toast.. use a proper DVD author app.
GB -
Hi
After trying this another way in Toast it all works fine.
I demuxed the Mpegs first then burnt the DVD in Toast.
After demuxing I dragged the picture file into Toast, where it then lets you know that there is no sound file and is it separate. You then pick the sound file. You do this for each Mpeg that you wish to burn to the DVD.
After the burn all is OK, no sound sync problems
Washac
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
