Results 1 to 28 of 28
    May 2004
    CANADA
    what program will do this and still have menu's and compress the video so they all fit on the dvd?
    DVD's are in IFO VOB format!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Are you serious????? 5 dvds to one disc will look HORRIBLE!
    You're best bet would be to reencode the whole lot to VCD and author with Tmpgenc Dvd Author (it will accept vcd and format it as dvd - actually MOST authoring programs SHOULD you'll just have to have the audio in 48khz).
    But seriously Full dvds can be as large as 7.5 gb. If your talking about 5 dual layer discs your gonna have HUGE compression ratios. Even 5 SINGLE layer dvds would look bad.
    Your best bet is to reencode them seperately.
    Look in the guides on the left.
    REALISTICLY you could put 2 or 3 movies on one disc but NOT 5!
    Kevin
    May 2004
    CANADA
    they are not full dvd;s they are exercise videos anywhere from 1gb to 3gb
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Ok you should have mentioned that first sorry for the rant
    Are these clipped from the dvds or are they the entire dvd???? (ie straight rip?).
    Either way you could use tmpgenc dvd author and simply import the vobs and create new menus.
    If they are from the original dvds intact you'll need dvdremake pro to retain the original menus. There are guides for that here on the left under "HOW TO" <-------
    Kevin
    May 2004
    CANADA
    they are from original dvd's i used dvd decrypter to put them on my harddrive, what step do u think i should take?
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    If you want to keep the menus use dvdremake pro and find one of the guides on this site.
    If you want to make your own menus use a programl like tmpgenc dvd author that will accept vob files
    Kevin
    May 2004
    CANADA
    i can actually keep the menu;s within each dvd?
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Well sort of - I remember the thread said you have a bridge menu that would link to the original menu.
    I've never done it so I can't tell you how exactly.
    Just do a forum search for "dvd remake pro" in the guides and you'll find what you need.
    Though it'd be a LOT easier to make your own menus. Also you could use screen shots from the various dvds as your background to make it look nicer
    Kevin
    May 2004
    CANADA
    it will compress it if its over the size?
  10. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Like I said I've never done it I just read about it here. If it's too large simply use dvdshrink to get it down to a manageable size (though you'll lose a little quality depending on how large it is ).
    Kevin
    EDIT - Here's MACEMX's guide for dvd remake:
    https://www.videohelp.com/guides.php?link=646
    Found it in the guides under "HOW TO" on the left of the screen <----
    It says just two dvds with menus but I assume since yours are small you should be able to apply the same principle to more than 2 dvds
    May 2004
    CANADA
    what i dont get is is asks me to merge 2 dvds at a time so since i have 5 what do i merge the fifth one with?>
  12. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I suggest you ask macemx - I've never done it.
    Kevin
    May 2004
    CANADA
    i sent him a PM...
  14. Banned
    Sep 2004
    Inner Circle of Thought
    Like Yoda, I tend to not encourage merging dvd's like what you want to do.
    It usually looks like garbage.
    May 2004
    CANADA
    i dont care about the way it looks, it only exercise videos
    May 2004
    CANADA
    all 5 dvds add up to 7.59gb so if i compress them all to 4.7gb it wont look that bad
  17. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    You know better. That's subjective. As the OP said, it's just exercise videos. I've got over 7 hours of video ready to go to DVD-9, but the target audience is a 2 year old on a 20" screen. I bet I don't hear any complaints about quality....
    EDIT: As pointed out.... I've also re-encoded both video and audio, "with the expert help of one of the forum regulars ".
  18. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I believe you can just merge them all with each other, in sequential order.
    Say we have DVDs A through E. Merge A & B to form AB. Merge AB & C to form ABC. Merge ABC & D to form ABCD. Merge ABCD & E and job's right.
    BTW, How did the project go, tekkie ?
    If in doubt, Google it.
  19. Banned
    Sep 2004
    Yes it is subjective.
    I was just giving my opinion.
    I walk away from this thread.
    May 2004
    CANADA
    i compress dvd 7.8 gigs to 4.7gb all the time and they look fine
  21. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    If you compress them to 4.7GB "all the time", then you already know that 4.7GB won't fit on a single DVD-R ...."all the time":
    https://www.videohelp.com/dvd#dvdsizes
  22. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
  23. Member
    May 2004
    CANADA
    im saying roughly relax dude
  24. Member
    May 2004
    CANADA
    i did that but when its going through the last project i get an error "ovf: the supplied user buffer is not valid for the requested operation"????????
  25. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    No idea, 'mon ...
    I've never used DVDRemake, so I'm not going to be much help. Maybe dimad can assist ?
  26. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    my lengthy complicated guide is outdated as the process is basically a few clicks now since it's been automated
    as jimmalenko mentioned, you can import 5 dvd's at one time and then just add 1 DVD in a new project. Worked for me but only with mini DVD's. The only thing is the default DVDRemake main menu only has 2 DVD's you can choose from . If you add more than 2 then you need to author your own menu
    is that what you are doing when merging projects and getting the error?
    you also have to change the button commands but I wrote a few mini guides on that recently somewhere in the forums (search my posts)
  27. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
  28. Member
    May 2004
    CANADA
    i guess i cant use dvd lab pro?
