does anyone know where I can buy 1x or 2x dvd -rw blank media for my pioneer 220s?
thanks
Caz
Results 1 to 11 of 11
Hello,
Can't ALL discs record at 1x regardless of the top rated speed???????
I don't believe this is so.Originally Posted by lenti_75
I remember reading on this forum or over at AVS that the DVD recorders cannot read/write to 4x DVD-RW
anyway, you can find 5-pack of Fuji DVD-RW at Best Buy for $9.99
the Sony DVD-RW 2-pack I bought at Target also works. -
The Pioneer DVR-220/225 happens to be one of the few recoders which can handle 4X DVD-RW (Version 1.2) as well as 2X DVD-RW (Version 1.1). You need at least 2X DVD-RW discs to perform simultaneous recording and playback, 1X discs won't be able to do those trick plays. Newegg.com has Ritek 4X DVD-RW discs for sale real cheap (less than $1 per disc) in 25-pack if you need to buy in bulk.
pioneer support says you can use 4x -rw so those who reported this are right thanks for all your help. what brands are you using on your pioneer 220-s
Robert Caswelll -
I would suggest against RITEK DVD-RW media.
TDK, Maxell, Fuji, Sony ... all in stores locally.
About $10-15 per 5-pack.Want my help? Ask here! (not via PM!)
NoOriginally Posted by yoda313
There are many discs that you can only start at 2x. -
Actually, it's your drive causing it, not the disc.Originally Posted by bazookaWant my help? Ask here! (not via PM!)
WhateverOriginally Posted by lordsmurf
My point was that sometimes, you can't do it.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer 220-S Replacement
By Shadow1861 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Dec 2008, 11:52 -
Pioneer DVR-220 and playing dual layer problem
By whitemtntn in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2008, 19:12 -
DVD Player Compatible with 2004 Pioneer DVR 220-S VR Mode of Recording
By iloveamerica11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Dec 2007, 12:14
