Hi guys,
About a week ago I installed the cd ripping software "furio", didn't like it and uninstalled it. Ever since, I'm unable to eject my DVD drives manually using the front buttons. The drives will eject manually after a fresh startup, but after putting in a disc they refuse to eject it - so I have to go to my computer, click the drive and click eject (sometimes repeatedly) to get the disc out. Also, the drives will continue spinning the disc, as if trying to read it, even when it's not being accessed. Auto-play/insert notification is not working on either drive either, even though I have it checked in the settings. I have an LG-4082b and a NEC ND-1300a. I've tried deleting/re-installing both drives with no success.
Anyone have any advice on what's causing this or how to correct it?
Much thanks,
Roy
I had a similar problem a while back when software was accessing my drives way past when I was done. Short of a clean install I would try a program such as startupcop or something else and see if there is a background application using your optical drives. Good luck. I finally went to XP and solved it.
Still a few bugs in the system...
Sony SLV-700HF VCR Won't eject tape...HELP
By bjo.love in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2012, 14:58 -
Panasonic DMR EZ28 Won't Eject Disc, Keeps Turning On & Off
By Garyrajsich in forum DVD & Blu-ray RecordersReplies: 3Last Post: 11th Jun 2011, 19:19 -
DVD Player won't eject. Philips DVP5992/37
By pops49 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Sep 2009, 17:59 -
DVD tray won't eject...
By zowiemagic in forum DVD & Blu-ray RecordersReplies: 6Last Post: 25th Dec 2007, 16:03 -
Samsung DVDRW Drive Won't Eject
By 888888 in forum DVD & Blu-ray WritersReplies: 4Last Post: 5th Nov 2007, 20:27
