Results 1 to 11 of 11
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    Hello everyone. I am having a problem working a game I purchased, NBA LIVE 2005, reason bieng that my video card does not have updated drivers. So I contacted TECH SUPPORT, and they said to contact my manufacturer. The problem is that I don't have a clue what my video card is (brand, type, etc.), where it is, manufacturer, or how to get updated drivers. Can anybody help a brother out?
    thanks.
    -skip2mylou
    Wow! You got shocks, pegs... LUCKY!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You have WIN XP - just go to www.microsoft.com and go to automatic updates. They USUALLY have links to updates for MUCH of your systems components.
    The other option - go to control panel and click on display. I forgot which tab but one of them will list the name of your video card. Write that down and then do a net search for it.
    One more option - search the comptuer for directx and start the diagnostic program. Then click the display tab and that will ALSO give you the name of your card.
    Kevin
  3. Even easier method(s).
    Go into device mangler and look under Display Adapters, or go to Start > Run > and type in: dxdiag.
    Cheers, Jim
    My DVDLab Guides
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Or even easier yet, right click your desktop, select properties, select the settings tab, select advanced, then select the adapter tab.....
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i found out that my what cha ma callit is called VgaSave. so do i search for the VgaSave site and get drivers from there?
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Never heard of them. You can try searching by the FCC ID (should be somewhere on the card). Look it up on Google.
    Nothing can stop me now, 'cause I don't care anymore.
  7. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    BTW, where exactly is the DEVICE MANAGER?
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Don't think there such a device.... http://www.subwolf.org/v2/articles.php?article=1 From what I can gather it's how windows names a display card it doesn't recognize.
    Control Panel>system>hardware>device manager>display adapters..... should list what your card is.
    If the card type isn't listed under device manager you'll need to take viral's advice. Go here to look up the code... https://gullfoss2.fcc.gov/prod/oet/cf/eas/reports/GenericSearch.cfm
    Are you sure it's a card and not onboard?
  9. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    YOU GUYS ROCK!!
    thanks everybody, i went to the device manager, and next to DIPLAY ADAPTERS, there was a "?", so i dubble clicked it, and i clicked re install driver, and the next thing i know all is well and good. thanks yall.
    -skip2mylou
  10. Member yoda313's Avatar
    Jun 2004
    The Animus
    YOU GUYS ROCK!!
    -skip2mylou
    Hello,
    Congratulations
    Chances are one of us here have had you're problem before. If not we know where to find the fix
    Kevin
  11. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    well i appreciate all everybody has done...thanks!!
    -skip2mylou
