  1. Original set of files in VIDEO_TS folder:
    VIDEO_TS.IFO 14.00 KB
    VTS_01_0.IFO 60.00 KB
    VTS_01_1.VOB 1023.99 MB
    VTS_01_2.VOB 1023.99 MB
    VTS_01_3.VOB 777.21 MB
    VTS_02_0.IFO 34.00 KB
    When I try and burn in Nero, I get:
    Required file 'VIDEO_TS.BUP' is not present
    Required file 'VTS_01_0.BUP' is not present
    Required file 'VTS_02_0.BUP' is not present
    DVD-Video files compliance test failed
    As a fix to this, I made a copy of each of the three ifo files and renamed them to bup so VIDEO_TS folder is now:
    VIDEO_TS.BUP 14.00 KB
    VTS_01_0.BUP 60.00 KB
    VTS_02_0.BUP 34.00 KB
    When I try and burn, I then get:
    Required file 'VIDEO_TS.VOB' is not present
    DVD-Video files reallocation failed
    Was my first fix correct (copy/rename the ifo to bup)? Or should I do something else or use a program to fix this?
    What is the fix for "Required file 'VIDEO_TS.VOB' is not present"? Or should I just ignore the error and burn the dvd?
    Thanks in advance for your help.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Remove or dispose of (Delete or move to another directory) every file except for the VOBs so you end up with:
    in a directory on their own (you could even just cut or copy these VOBS to a new directory).
    Then follow this guide, then follow this guide.
    If in doubt, Google it.
  3. jimmalenko, thank you very much...I finally got around to doing what you outlined and it worked perfectly!
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    No problem
