I am using dvdremake and for some reason, after the video segments are removed, in one stand alone player, the video jumps to the next chapter without playing much.
This is what happens, I select play all episodes (or whatever) and the video starts to play... it gets to chap 1, plays for half second, pauses for half second, goes to next chapter, plays for half second, pauses for half second then goes to the next chapter, etc. until it reaches the end of the disk.
It only does this one on player for this particular DVD disk. (others DVD disks work fine for this player for some time.)
I mention I am using DVDremake, but I am not sure if this is the cause of the problem or not!? I use dvddecrypter too. then dvdremake, then dvdshrink, the nero.
I was thinking if it is NOT dvdremake at issue here, could be some other program? Perhaps there are some jump commands or something out of wack in the IFO file?
Where do I start to figure out the problem of these dvd videos?
Thanks!
Results 1 to 1 of 1
pcexpress-guy
windows 7 command line problem with the % symbol
By sonic12345 in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 15:45 -
VOB2MPG command line problem
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Mar 2010, 14:58 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 03:23 -
DVDremake Pro button problem
By Yaro in forum EditingReplies: 2Last Post: 16th Aug 2009, 17:54 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
