I just purchased philips DVD714AT. It is capable of VCD and MP3 playback. Burning MP3 using easy cd creator v4.0 produces cd's that play on the DVD player. I downloaded the sample NTSC VCD file from vcdhelp and used cd creator to transfer to cd. This file xxxx.mpg on the cd plays back on the computer using windows mediaplayer but the DVD player does not recognize the file. I have read a bit on this site regarding authoring however some question remains as to whether I am burning a vcd file or do I need to post process the sample file downloaded to make it into a compliant vcd file? Any ideas?
raka
I have EASY CD Creator 4.05. How did u burn a VCD with 4.00 when 4.05 doesn't even have that?
I might be mistaken but it soulds like you just burned the mpeg file to a PC data CD (mode1) and tried to play it. This won't work. x(S)VCD need to be burned in MODE2 and require a certain file structure.
I'm not sure what programs you have. But take a look at:
http://www.vcdhelp.com/vcdeasy.htm
You can d/load the newest VCDImager Easy Bundle at http://www.doom9.org (under downloads | full page)
Or if Easy CD Creator has VCD template/wizard that 'should' work (I don't have the program).
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15
