  1. By mistake I recorded a program the other day with a funny file format - it's MPEG2, 720x576, with an audio sample rate of 44100. Any suggestions of what I can use to turn it into a valid PAL SVCD?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    tmpgenc should do it for you. Load the mpeg into tmpgenc and select the pal svcd template.
    Kevin
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...provided you have the mpeg2 plugin for TMPGEnc (or PowerDVD installed).
    /Mats
  4. Thanks for the suggestion. I just tried it, but tmpgenc refuses to open it - as does SVCD2DVDMPG. DVD lab will demux it, Nero Vision Express converted it OK, but the video came out jerky (which it isn't in the original)
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    What did you use to record it?
    Anyway, you could try opening it with VirtualDubMod, frameserve to TMPGEnc for reencoding to SVCD specs.
    /Mats
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd try raising the priority of your MPEG-2 codec. If that fails, I'd frameserve with DVD2AVI into TMPGEnc.
    If in doubt, Google it.
  7. Member monzie's Avatar
    Nov 2003
    The Village
    Be careful when encoding SVCD's...too high a bitrate often leads to jerkiness/freezing....try lowering the max to around 2200...with an ave of around 1600-2000...set the min at 500.
