My source has a resolution of 448x336 @ 24 FPS:
Should I encode to CVD: 352x480 or VCD: 352x240
Any suggestions?
Hello,
VCD will get more time at lower quality and nearly 100% compatibility.
CVD will be much less time and nearly no compatibility.
VCD is my vote
Lets ask this way: Compatiblity and the time that should fit on the disc doesn't matter, only the qualilty counts: (encoding with VBR at 1732 kbits/s)
So again, source res is 448x336 @ 24 FPS:
CVD: 352x480 or
VCD: 352x240
Should I better upsize or downsize the source resolution? -
It doesn't matter if you make cvd or vcd if know how to change picture size without stretching.
If you wish to keep the resolution, go with 480x480. If you don't mind the smaller size, go with 352x240. Whichever way you choose, use a crop filter and get rid of all the black borders around the picture screen, then set the aspect ratio to "full screen (keep aspect ratio 2)" if you're using Tmpgenc. That will keep the picture from stretching.
What is The Best Script To Encode a Resized VCD Rip in Megui??
By a6hatesme in forum Authoring (VCD/SVCD)Replies: 10Last Post: 27th Mar 2012, 19:47 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
