Okay. I followed the tutorial on how to convert an AVI to MPEG2 for DVD using TEMPGEnc 2.1. When I try to drag the MPEG file into Ulead DVD Movie Factory, I get an error message "...is not a DVD MPEG. Please select a DVD compliant MPEG file." Any ideas? I have triple-checked all the settings in the tutorial. The only one I didn't adjust was settings under the rate control mode. The default settings there are 50 for quality and 3000 for maximum bitrate. Is there something I need to do here to make the file compliant? Thanks.
Results 1 to 9 of 9
Have you downloaded Sefy's template pack for TMPGEnc? Try the DVD template (the only marked as DVD, the rest are svcd, vcd, etc.).
Okay, where do I find it? I looked under tools. The only templates under Sefy's name have nothing to do with DVD. Is it somewhere else, on his own site perhaps?
Yeah, i'm curious too, I remember in the past working on a SxDVD, but I don't recall ever spreading it, how did my name get next to a DVD ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
You could also try de-muxing and re-muxing your video stream in bbMPEG using the DVD settings. Its likely that your problem is not with the encoding itself, but some aspect of the multiplexing.
Sefy, I've downloaded a pack of templates for TMPGEnc that you've created or some that you've downloaded from somebody through I guess e-mail. Hey Sefy, I'm still waiting on that compliant VCD burning software list for my "Panasonic DVD-RV30".
BaDbOy3998, Did you try checking the DVD Players list here to see what would work best for your model ?
Best Regards,
Sefy Levy,
I had the same problem.. discovered that you have to use the 'Batch Convert' on the edit menu....theres no reference to having to do this in the help... I managed to get this far, but now I can't join the files in 'Make Movie'
Gnarly
Who ever dies with the most DVDs wins!
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
MPEG2-->MPEG2 Crop + Resize
By wincrazy in forum Newbie / General discussionsReplies: 26Last Post: 24th Jan 2009, 01:30 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
