  1. Hi All
    I made a DVD using Sizzle and it all works fine on my Mac.
    When I put this DVD into my standalone player the picture size is BIGGER then my TV screen, any advice on setttings within Sizzle to rectify this problem?
    Washac
  2. i assume the text on your menus are being cut off? if so, just account for the "overscan" by moving the text inward a tad. sorta like on idvd when it shows you the "tv safe" option.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    That or some dvd players have a zoom ability. perhaps you can "unzoom"
  4. Hi
    Thanks for the replies, I will try both methods.
    Washac
