I've been using dvd-lab with pretty good sucess for about a year now. Yesterday, a client wanted to not only enlist my services to film an instructional dvd, but he wants to go to the expense of having the disk pressed for resale. I've seen some posts that say that dvd-lab isn't 100% dvd compliant (of which I don't know the specifics of) but haven't had any personal experience with disks failing because of authoring anomolies. The question I have is this: If I have dvd's pressed using a disk authored in dvd-lab, will I run into problems? I would hate to plunk down $1800 to have 500 disks pressed and find out that they don't work the way I want them to.
TIA.
Results 1 to 12 of 12
There are a number of people who use DVD Lab / Pro commercially, and to create masters for pressing. Outside of Maestro or Scenarist, I doubt any package could guarrantee 100% compliance every time.
The bigger issue you may have is if your pressing service requires the master on DAT. I believe only the Pro version supports this. Some services will take a DVD-R as a master - so check with them to see what they require.Read my blog here.
I've never had any problems sending my DVD masters done in DVD-Lab or DVD-Lab Pro to a pressing plant. I send them a DVD-R with AC3 audio burned at 2x on Taiyo Yudens.
Sometimes my DVDs freeze on one of my DVD players when I make a DVD using DVD-lab Pro (latest version) but when I use DVD Architect 2 it plays just fine. And just so you know I used the same files on both programs.
Compliance also depends on complexity as well. If it's a simple title that isn't manipulating a bunch of variables, there are less things that can go wrong with it.Originally Posted by guns1inger
Replication facilities can master from DLT-III and DLT IV tapes. Many take DVD-Rs for single layer titles.
Is your title single layer, Red? -
$1,800 and 500 disks...
Could you just make the master and have one pressed disk made as a sample? I believe at Wolfcamera you can send video off to be put on a pressed DVD disk.
Tearren -
It's DLT but there really is nothing to making a DLT to handoff for pressing. You just copy over your DVD folders to a tape and hand it to whoever. Duplication houses only prefer DLT because it isn't as finicky as ink in DVDR media.Originally Posted by guns1inger
So even though, a DVD Authoring program does not support transfer to DLT, all you have to do is copy it over.Your miserable life is not worth the reversal of a Custer decision. -
freestyler.
I'm shooting for a dvd-5. I suppose I could master it to a dvd+rdl, but I'm going to keep the instruction to just over an hour.
Tearren.
$1800 for 500 disks is pretty cheap. Consider that the wholesale price for the disks will be about $10ea ($3200 potential profit). Additionally, some disks will be sold directly from the clients website at $25ea ($10700 potential profit)....makes that $1800 look like a sweet deal, eh? -
Red96TA wrote:
Very sweet indeed.Tearren.
I was just saying, to me, $1,800 would be a huge commitment for something I wasn't sure would work. So, I just suggested making a 'test' disk before doing the whole run. -
Here's a quote I got for an upcoming project. For Pressed DVD's.
https://www.videohelp.com/forum/viewtopic.php?t=250505
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 09:21 -
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
Windows Movie Maker Will Not Start Timeline When Pressing Play
By kerrex_2006 in forum Software PlayingReplies: 0Last Post: 8th Apr 2010, 12:10 -
Pressing Capture Button Freezes Program
By Mengsk in forum Capturing and VCRReplies: 13Last Post: 5th Jun 2008, 17:45 -
Have your NERO & sub it too... add subs to episodic DVD's with DVD-lab
By KneeRow in forum User guidesReplies: 1Last Post: 24th Aug 2007, 02:16
