  1. I have had this Burner for about a year..I upgraded to the latest REV 1.08 firmware upgrade. All of the sudden my 106D does not recognize CD-RW? It recognizes CD-R's, DVD-r's etc.. This just happened..I used DVD Info and it says there is "no media present" even when there is a CD-RW in the drive. Windows Explorer also does not recognize the media as well. I am using Memorex 1-4x CD-RW. I did not have a problem until now. I've seen others with the same problems looking through other posts. Can someone please help?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Perhaps flash it back to the firmware you had ?
    If in doubt, Google it.
  3. jimmalenko. Thanks for the quick response.
    This problem existed when I had the old firmware 1.05 installed. I upgraded to the new firmware to see if that would fix the problem. Do you have any suggestions other than getting a new drive?
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Clean the lens, try different CD-RW media ...
    Can you remember when CD-RWs were working ?
    Any firmwares that have worked with CD-RW in the past ?
  5. I used system restor and went to a restore point before the CD-RW's stopped reading. Now the drive reads the CD-RW's...Strange but I guess that did the trick.
