Results 1 to 11 of 11
    Feb 2003
    U.S.A.
    I recently "moved" some MPEG files from an NTFS hard drive to a DVD+RW (packet writing) and now I find that a couple of them are "0 bytes" on the DVD. The original files were deleted from the hard drive after they were "moved" so how can I recover these files? I have not overwritten anything, but I've tried a couple file recovery programs and I can't find any recently deleted files on the HDD. What am I doing wrong?
    Feb 2003
    U.S.A.
    Forgot to mention - it's an external drive if it makes any difference.
  3. I would have recommended recovery programs too. You must have had a couple errors while burning. I would recommend trying PC Inspector Smart Recovery if you haven't already, you can find it at www.download.com[/quote]
  4. Running Xp . Try system restore.
    Not bothered by small problems...
    Spend a night alone with a mosquito
  5. Running Xp . Try system restore.
    good call
    Feb 2003
    U.S.A.
    Tried PC Inspector, gave me a read error about an invalid address. Tried several similiar programs and they couldn't find any recently deleted files, only some deleted ages ago. I didn't write anything to the drive since I found the copying error, so they have to still be there somewhere.
    Are you sure System Restore works with files? I thought it only restored installed programs, but I will give a try anyway.
  7. Tried PC Inspector, gave me a read error about an invalid address. Tried several similiar programs and they couldn't find any recently deleted files, only some deleted ages ago. I didn't write anything to the drive since I found the copying error, so they have to still be there somewhere.
    From my understanding of it it restores system settings, but leaves your files intact. But I guess its worth a try.
  8. restorer2000
    Originally Posted by jagabo
  9. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Lost & Found is another good one.
    Nothing can stop me now, 'cause I don't care anymore.
    Feb 2003
    U.S.A.
    System Restore did not work. I put the drive inside the computer to see if there was any difference, but none. Any other free programs besides PC Inspector and FreeUndelete? Looks like I will need one that does a sector by sector search. The 2 deleted files aren't worth that much to me, so I don't want to pay for a program.
    PC Inspector keeps giving me this message:
    Access violation at address 004BD159 in module "filerecovery.exe". Read of address 00000030.
  11. System Restore did not work. I put the drive inside the computer to see if there was any difference, but none. Any other free programs besides PC Inspector and FreeUndelete? Looks like I will need one that does a sector by sector search. The 2 deleted files aren't worth that much to me, so I don't want to pay for a program.
    You should try the trial of some of the trialware programs. Usually the trial will at least show you if it can recover a file, it just won't save it. Its worth a shot to see if its even recoverable.
