Happy Holidays everyone! I am hoping one of you gracious folks can help me with a problem that I'm very close to ripping my hair out over! I keep getting a buzzing noise when I try and play my dvds. I have video, but only buzzing audio. I have a TEAC DV-W58E burner, a KOSS 4110 standalone and a cyberhome 300 dvd player. I have tried the following:
imation rw dvd+rw 2x = good on KOSS
fujifilm dvd+r 4x = good with original to copy, bad with avi to dvd (buzz sound) - Cyberhome
HP dvd+R 8x = buzz sound on Cyberhome
HP DVD+RW 4x = buzz sound on cyberhome
Ritek dvd+r 4x = good with original to copy, not sure about avi to dvd
I also have another dvd player that plays pretty much everything.
I use canopus, besweet, TDA, and copytodvd to make my avi to dvd. 224 audio.
I need to find a media that will work with my burner and three dvd players. One is my grandfathers and I'm trying to give him so things to watch, but I'm having no luck. I'm thinking this may be an audio issue since original to copys always seem to work...but when I create my own from an avi it doesn't. Can anyone help?
Results 1 to 12 of 12
What type of Canopus do you have? Just curious because if it is the ADVC-100 then the audio should be locked in sync with the video. What I am driving at is that it seems as though you really do not need to use Besweet.
My suggestion, since you already have TDA is to use CCE Basic to convert
your avi to compliant MPEG and then author and burn your DVD with TDA. Leave the audio alone. CCE Basic is an excellent avi to mpeg converter and is reasonably priced at $58.
wwjd -
Use LPCM audio or AC-3 audo but DO NOT use MP2 audio.
The kind of disc makes no difference. Data is data is data.
I use Procoder, which gives me two streams a video and an audio. I use Besweet to convert the .wav to an AC3 file. I wouldn't mind creating a 5.1 dolby digital audio to use but I havent' figured that out yet.. I really haven't had any problems with sync. I'm just wondering how good the quality is of the sound file that Procoder gives me?Originally Posted by wwjd
Why will some disks work on standalones and others will not?Originally Posted by lordsmurf
I don't know if it play alright or not, POWERDVD is not working anymore. I used this guide but used the audio from Procoder instead and Besweet to convertOriginally Posted by guns1inger
https://www.videohelp.com/forum/userguides/129419.php -
If you need another software DVD player, try Media Player Classic. It's small, free, and fast. I prefer it over PowerDVD most of the time. And it's only one file, with no installation required. So nice.
Is there a difference in sound quality with PCM like what I get when I load AVI into Canopus and it spits out an audio stream and AC3 which I get from loading that audio stream into Besweet and converting it? It seems as though my dvds are now working when I don't use Besweet to convert to AC3. Is there anyway to convert an avi file to audio with 5.1 dolby digital? I think most of the stuff I have is only two channel though...
Hello,
First of all the player may or may not be able to play the -r or +r type (old ones may not like them).Originally Posted by intuit
Second of all - MEDIA QUALITY. Though I've never had a problem with el cheapo discs if you don't get good quality discs you very well may have trouble playing them.
Third - Authoring - if somethings not done right sometimes it may not play correctly. Or if the structure got corrupted some how.
There - it's usually the disc itself not the stuff on it - though if it's not in proper dvd format it might not play properly either.
Kevin
(and also - it's BURNED not PRESSED - so it won't work 100% of the time on 100% of the players. That's the nature of recordable media
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If its a stereo source then I wouldnt even bother. It would require the use of some pretty crazy audio editing software and you probably wont get as good of quallity as you would just running your stereo track in Pro Logic or Neo:6 mode on your DVD Player/Receiver.Originally Posted by Intuit
For stereo vids, (ie: Divx AVI w/ MP3 stream) I usually just rip the audio stream to wav using VirtualDubMod, convert to AC3 using BeSweet, and then run it through AC3Fix to make sure its DVD compliant.
For 5.1 vids (which should already have an AC3 stream) I use the Demux option in VirtualDubMod and then run it through AC3Fix (might not always be required, but its good to be safe)
Which variables make best video quality in MKVs? bitrate/profile/ref frames
By dave in or in forum Video ConversionReplies: 9Last Post: 1st Mar 2012, 16:25 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 21:34 -
Frustrated Sony HDR-SR12 Owner
By jehill in forum Newbie / General discussionsReplies: 20Last Post: 5th Jul 2009, 04:54 -
frustrated with VDMOD and MSU sub remover
By volam in forum SubtitleReplies: 1Last Post: 7th Feb 2008, 09:45 -
Substituting Variables in a Wiki Template
By thecoalman in forum ComputerReplies: 1Last Post: 14th Jul 2007, 05:00
