Results 1 to 9 of 9
    Nov 2004
    South Spain
    Hi
    I've set my heart on the Pioneer 108 after week after week of searching the net & talking with friends.
    However I saw the Benq DW1620 for €60 which is €18 cheaper than the Pioneer. The NEC3500 is just a tad more expensive than the Benq too.
    So the question is should I stick with my original decision or go with the Benq & save a few 'quid'? I already have 50 DVD-R discs... My main concern is good quality burns & good compatibility.
    Many thanks
    Nat
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Spend a little more and get the quality Pioneer 108.
    Nobody likes a bunch of yackity-yack.
  3. Banned
    Sep 2004
    Inner Circle of Thought
    Pioneer makes great burners.
    I suggest the pioneer.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I've got 3 different Pioneer drives and they've all been fantastic - I've only ever used DVD-R media with them FWIW.
    If in doubt, Google it.
  5. I still use my Nec 1100....
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Thanks for sharing
  7. Member Skith's Avatar
    Bottom of the ocean
    Pioneer excells at the -R/RW media. 16x recording with the 108 is actually takes longer than most other drives at 12x.
    The BenQ 1620 performs better with + (plus) media, and is getting better with -R/RW with every firmware update. The BenQ also "officially" supports "bitsetting" to DVD-ROM, as well as allowing a large number of media to be "overspeed." (example: Taiyo Yuden 8x +R media rated at 8x can be recorded at 16x). The BenQ is also records media faster.
    The NEC3500A (I would hold off, the NEC 3520 is on the way - see www.cdrinfo.com). I have the NEC, it is a great drive. There is also a huge amount of "unofficial" support for this drive - in the form of "hacked/modified/enhanced" firmwares. *modified firmwares will VOID ANY WARRANTY!*
    Check out the respective forums at http://club.cdfreaks.com (under DVD-Writers - there are forums for each manufacturer).
    *Note about bitsetting/booktype. Many people consider it a requirement if they are burning +R DL media. It also improves compatability of +R (single layer) media in stand alone players to the same level as -R media. ***This is OPINION based on the research I have done on the subject. Sources - this site, cdrinfo.com, cdfreaks.com, cdrlabs.com, and more.
    good luck
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  8. My two NECs have been awesome burners (1300 and 2500).
  9. The BenQ dw1620 is more touchy in what external case you use, if you get this burner, you'll have to do some research which external case to get.
