Hello,
I'm pretty sure this is not a problem, but just to be certain.. there is no problem with having different audio tracks with different bitrates on a DVD correct? For example one AC3 w/ 256kbps, another with 224kbps?
Hello,
I believe that should be just fine. If you notice on bonus discs most often the documentaries use a low bitrate like 192 or something. Most often the trailers are higher like 256 unless they are really old and non stereo. So there shouldn't be any problem.
Of course a rule of thumb is to always burn to a rewritable first to test it out
No problems,as long as you put the different audio on separate tracks.
Different VTS
Does Bluray support standard definition bitrates above DVD Maximum?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 16Last Post: 14th Feb 2012, 16:27 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Need some education on Audio formats used in DVD's (standard and Bluray)
By nzdreamer55 in forum Newbie / General discussionsReplies: 10Last Post: 7th Apr 2011, 21:09 -
Can you copy multiple mini-DVD discs to one standard DVD?
By darkcyber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jan 2011, 09:44 -
multiple .avi files on a DVD-R that is viewable on a standard DVD player
By ottawadave in forum Video ConversionReplies: 8Last Post: 18th Jul 2007, 11:32
