    -> here
    selecting an m2v and mp2 file, muxing as xsvcd, post -processing: author as SVCD / Split in 2 chunks, works fine until the 2 mpgs have been created, than the process stops:
    Size of Fix: 0x914
    now reapplying junk-header ....
    Now processing /Users/xxxx/xxxx/xxxx/xxxx_xxxx_xxxx/ichi.mpg-0.mpg [1/2] ...
    Now processing /Users/xxxx/xxxx/xxxx/xxxx_xxxx_xxxx/ichi.mpg-0.mpg [2/2] ...
    -------Done--------
    /bin/sh: line 1: /Library/Application: No such file or directory
    everything is installed where it has to be
    cheers
    f.
  2. Thanks for your report. A small bug of mine introduced with some changes I made in 0.0.9r. I will fix it, in the meantime use the AUTHOR tool on each chunk.
  3. I fixed it. Download again ffmpegX and let me know if it works now.
    -> here
    thank you!
    i already trashed the demuxed files and authored the two chunks with the author tool. in case it should happen again with the last update i will inform you.
    cheers,
    f.
