  1. I tried opening a avi file in VirtualDub 1.6.2. and I got this error.
    Couldn't locate decompressor for format "DIV3"(Microsoft High-Speed MPEG-4 V3 [HackivX Low Motion])
    VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by a Windows Media Player, are not suitable.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    You need to install a Divx or other MPEG4 codec that your software can utilize Try the web page for the software vendor under "Support"
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    https://www.videohelp.com/play.htm#identify
    This will tell you what codec you need. Then download and install it from the tools section.
    If in doubt, Google it.
    Dec 2004
    Australia
    Tachnically DivX/MS MPEG4 is not MPEG4, however some MPEG4 codecs like DivX and 3ivX also handle it as does ffdshow. Then there is the actual DivX311alpha codec. Personally I would go with ffdshow.
  5. i downloaded the ffdshow but i have no idea how to use it...
    Dec 2004
    Australia
    Just make sure that in the VFW decoder settings DivX 3 is set to libavcodec and not disabled.
