i want to buy a dvd recorder that is easy to use, good quality, prize doesn't matter. i like to burn clips from my sony DV camera on a dvd and i like to convert videos to DVD.
is panasonic DMRE95HEBSM the best i can find?
thankx
Results 1 to 22 of 22
Didn't I just lock your other thread?
https://www.videohelp.com/forum/viewtopic.php?t=250259
Redundant questions. Anyway, be sure to READ THOSE OTHER THREADS.
I would highly recommend the JVC, and it has a very nice iLINK feature to transfer from DV.Want my help? Ask here! (not via PM!)
Panasonic, read my experience here: https://www.videohelp.com/forum/viewtopic.php?t=250299
Get the Panasonic. JVC reportedly has some problems. The picture quality on the Panny units is outstanding, No matter what, do not get suckered into buying Liteon or Ilo.
Panasonic consistently scores the best in every test review around the world (CHECK THE THREADS). This brand has the best-rounded models regarding the quality of the recordings, reliability, flexibility and simplicity of use.
Have a look on the threads in this forum. It is obvious that the longest and most “popular” ones talk about fixing the problems of the DVD recorders. How many of them are about the Panasonic models?
These long threads visited by countless number of frustrated members are about the DVD recorders that are always highly recommended from a few frequent and loud “experts” on this forum. If you want to be a member of these groups and learn how to troubleshoot, repair and upgrade DVD recorders, then buy one of those machines. If not, buy a Panasonic.
The choice is embarrassly simple. -
Why go with Panny or JVC, when you can own a Pioneer. Compare & research yourself!! Its the best.
panasonic
can't go wrong, up there with the best
also bought the sony hx900 thinking there was this magical blow out vid quality for me to witness compared to the panny's, heh not so
imho i could not tell a difference, maybe i can with a magnifying glass? lol -
WOW!!!!!!!!!!!!!!!
LordSmurf Says JVC, but everyone else who posted says PANNY!!!!!
Hmmmm.... i own a panny!!!!!!!!!!!!
Never owned a Panny, but I have a JVC and a Sharp (second cousin to a Pioneer) and JVC has a little better picture (cleans up noisy sources amazingly well). My JVC has a defective tuner though, but recording thru A/V inputs is fine. No one else has had this complaint about a JVC, so I would assume mine is just a fluke.
More JVC/Panasonic comparisons here:
http://forum.ecoustics.com/bbs/messages/2/68501.html -
i bought a panasonic E95H atlast lol....but i can't plug it to sky box and t.v
atlast i could plug it in
i burnt a dvd using dvd-r but it only shows on the dvd-recorder not on other dvd players or my laptop . why? -
yeh...after finishing...i look at t.v screen it said...finalizing from 1% to 100% ..then it finished and i could watch it on ONLY my the dvd-recorder that i burnt the dvd-r
Are you sure the screen that had the progress percentage wasn't the cache emptying just after the recording stopped?Originally Posted by l3ahraivi
Finalizing takes about 4 minutes on a Panny. How long did yours take?
Try this:
Put the disc in and after it finishes reading it, use the function button to go to the menu. Select disc options and see if you can start finalizing the disc from there. I suspect you didn't finalize it. -
My panny takes like 10 minutes at least to finalize a dvd-r........
Do you usually record partial discs? I've noticed that partial burns take quite a while longer to finalize.Originally Posted by Noahtuck
Yeah, now that you mention it it was a partial disc, i was just testing something because i usually only use ram disc's.
I hardly never use dvd-r in mine. -
I think I remember seeing somewhere that a DVD needs at least 1G to be compliant. Maybe its filling up the disk to at least 1G with dummy data.
It's not dummy data, just a huge lead-out.Originally Posted by BSRWant my help? Ask here! (not via PM!)
Panasonic AG-1980P vs JVC HR-S9800 / SR-V10U
By lordsmurf in forum RestorationReplies: 72Last Post: 6th Apr 2016, 05:21 -
Panasonic AG-1970 or JVC HR-S7900U
By magillagorilla in forum Capturing and VCRReplies: 7Last Post: 24th Jan 2011, 00:27 -
Please tell me to use my Panasonic AG 1980 instead of my JVC HR-S5912U
By Anonymous4 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2009, 15:01 -
How to hook up a jvc 30000 to a panasonic dmr-85
By 2boot in forum RestorationReplies: 0Last Post: 16th Mar 2008, 15:26 -
Panasonic ES10 vs JVC MH300 for VHS
By djnice in forum RestorationReplies: 7Last Post: 1st Jun 2007, 14:23
