Guys,
Once I used DVD Decrypter to copy the files to my HD which software is better to use to rip the files to the DVD-R within Shrink, Nero or Decrypter?
Moving to DVD-to-DVDR Forum ....
You don't "rip" them to DVD-R....you just burn. I prefer Nero myself, but mileage will vary
Take your pick
Many will tell you decrypter.
I use Nero and it works fine. -
The term "rip" is used for extracting copy-protected material from optical disc to files. It's used for CDs and DVDs. Just so you know for future posts
I have a Pioneer 106D Burner and now have no problems at all using the following method.
1. Use Shrink to re-author and backup to a single ISO file.
2. Then burn with DVD Decriptor.
(both applications are free)
Your drive should be formatted NTFS to enable you to create a single ISO file using DVD Shrink, then burn with DVD Decrypter. If your drive is formatted Fat32 then you will need to split the ISO images into 1 gig files and then burn with DVD Decrypter.
No coasters, no skips or freezes and a backup that is hard pick from the original DVD, more importantly, I use the cheapest DVD media I can find which at this time are 4X-R Princo which are considered rubbish by many members of this site.
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 15:54 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
RipIt4Me, DVD Shrink, and DVD Decrypter on Vista?
By RowMan in forum DVD RippingReplies: 1Last Post: 24th Oct 2007, 23:45
